Using the Mountain Directory e-Book to Find Steep Hills
This is the Home page of the Mountain Directory West e-Book. On the map, each Yellow triangle is a mountain pass and you can see it covers lots of them in the West. Click on the state button and you’ll be taken to all the mountain passes in that state.
You might think, “Well, I’ll just go around them.” Often that’s the best idea but there are three problems with it:
- Snowbirds need to go up into the mountains to find cool weather and that forces you to drive these steep hills. For that we need to know which is the easiest route into the cool mountains.
- In much of the west there simply is no alternative, you either go over the mountains or drive 1000 miles out of your way to avoid them. In that case, we need to know which of the mountain passes will be the easiest.
- Much of the magnificent beauty of the west is a lot like a pot of gold at the end of the rainbow and it’s either in the mountain pass itself or on the other side of it.
This was my camp after climbing the “Oh My God Hill.” There literally was a rainbow at the end of it!
This is the bottom half of the home page map and explanation for it. I find it very useful because you can tell at a glance if an area has a high or low elevation, which will tell you what you can expect the temperatures to be generally. In the summer, dark brown will be cool and dark green will be very hot.
This is a page out of the Mountain Directory West e-Book covering Wyoming.The yellow triangles on the map are live links and you can click on them and learn all about that pass. The number of the pass is based on it’s difficulty. The Bear Tooth Pass is number 1, and the Oh My God Hill is number 2. If it were me, I’d reverse that.
Not all mountain passes are in the mountains. This is the Moki Dugway in Utah, and it is quite a climb from the desert!
This is how the Mountain Directory West describes the Moki Dugway. I think it is an excellent description of what to expect. I’ve circled it’s yellow triangle with a purple circle. It’s not a difficult hill, but because the road is dirt, it’s very narrow and has a very steep drop-off, if you have a fear of heights you should avoid it.
Fortunately, the ”Mountain Directory West” describes the curves and their speed, giving you a true description of the hills difficulty.
Another thing I really like about it, is that the maps do a very good job of visually showing you where the mountains and the valleys are. So when I plan my route I can look at the map and know at a glance when I’ll be in the hot lowlands (color coded tan or green)and then climb up into the cool mountains (darker brown) and by looking at the description of the Pass I know how difficult the climb will be up into the mountains
Why is it important to know in advance about bad hills? There are two reasons:
- You can avoid the hill altogether by finding a different route. Because I’m writing a book about mountain passes, I didn’t have the option to skip hills, but most of you do. For example, there are 5 routes into Yellowstone, and you probably will only drive two, one on the way into it and one on the way out. So by using this book, you can chose either the hardest and most beautiful (the two usually go together) or the easiest. In some places, you may want to simply back-track and do a circle to avoid a particular hill. That’s true about the “Oh My God Hill” I described in my last travel post, in that case you have two other much easier ways to get to the top and avoid what is the worst hill I’ve ever driven.
- Knowing how long and steep a hill is in advance, you can pull over and stop to let the brakes and engine cool. You can stretch your legs, get a bottle of water, enjoy the view and take some pictures. In that way you’ve taken what might have been a stressful, unpleasant or even dangerous experience, and turned it into a pure pleasure. The problem is that most of us think to ourselves, “I’m almost to the top, so I’ll just keep going.” But too often, we’ve only just begun and the worst is still ahead! If we keep pushing our way up or down the hill, we not only ruin the joy of the experience, we place ourselves in danger. With this book, you’ll know exactly where you are on the hill and how much worse it gets ahead.
I’m giving you a link to get the Mountain Directory E-Book, but I should tell you that I will make a little money on each one sold. I hope you know that is not my motivation in encouraging you to buy one, I honestly believe every traveler should own one of these and use it often! I can guarantee you that I will never be without one!
Even if you live back east, you still need a Mountain Directory East. These signs are on Route 226 in North Carolina and knowing about them would be a big help if you live in the area.
Purchase the Mountain Directory East or West from this link, and I’ll make a small amount on your purchase and it won’t cost you anything extra: Click Here!
In my next post I’ll give you details on understanding what the percentage grade numbers mean and how you can use them to stay safe and comfortable. I’ll also give you safety tips for climbing and descending steep hills.
One last thing, the book doesn’t claim to have every single mountain pass in the country but it does cover the vast majority. In my travels this last summer I only found one that I wish had been included but wasn’t and it wasn’t all that bad.
Too bad for those of us with Macs or only handheld devices: “These ebooks are designed exclusively for PCs and laptops running Windows.”
I’m using LinuxMint 17.2 with Mozilla Firefox. The demo linked on Amazon worked for me, as far as I could tell. It also seemed to work on my Android 4.2.2 tablet. However, the demo is pretty simple; the only difference from browsing is that it scrolls the map versus the directions separately.
Incidentally, on the main page for the book, the Eastern sample is the pass I mentioned in my comment on the “Oh My God” Hill post. The eastern summit turns out to be 4 1/2 miles up (eastbound) and 4 miles down a 9% grade shaped like overcooked spaghetti. The view at the summit is beautiful, and there’s a nice place to pull over. Wile we were there, we saw a bicycle traveler summit westbound and head down without stopping. Wow!
Sorry about that LaVonne, I didn’t even notice that.
It costs about $80, but there is a program that you can use to run Windows on your Mac, called Parallels.
I think you’d have to buy the Windows operating system too.
Just thought I’d throw that out there.
I use virtualbox, which is free. You do need the Windows OS to install on it though.
You can also try wine, which will run some widows programs without installing the OS.
Ming says “You can also try wine”
Don’t mind if I do…cheers
lol!
Thanks Ming, those are good tips.
Thanks Brigitta, there are many programs that are Windows only so I would think that would be a very good thing to have.
I’ve used the “The Mountain Directory” (both editions) for many years; the latest publication date for the paper editions was 2006. If one wants to find the resource in paper, search using the title on the websites of new and used book sellers. I consider this guide to be an essential resource, particularly when traveling in the west in a “large” vehicle.
I couldn’t agree more JT!
Earlier this week I drove all the way across Nevada, from Carson City to Great Basin NP. Nevada has more mountain ranges than any other state. It’s the Shar Pei of states. Driving east-west across Nevada is one 7,000+ foot pass after another separated by flat basins. Coasting down from the summit makes up for the slog up. Wheeeeee!
Al, it does indeed have many mountain ranges. Nevada is a real paradox, it seems like its all flat desert and then you swear it’s all mountains and forests.
Either way it gets you!
We have an old copy of that Book and it’s well-worn and well used! I’m glad it’s still available as an e-book. They also offer it as an App now, but I’ve never used the app version. Great tips for mountain driving!
Nina
Thanks so much Nina! With your beast it is probably very important!
You’re probably familiar with any scenic road in Colorado, but if you’re still collecting input on them for your book, I’d add hwy 65 over Grand Mesa. I don’t know of any boondocking places, but there’s a national forest on it, so I’d imagine there are opportunities. A nice place to cool down during a hot summer.
Great suggestion on the Mountain Directory book.
Thanks Jim, great tip!
