Andrew's Craftsman Van Conversion
Andrew picked up this very nice high-top conversion van for not much money and turned it into a wonderful home. His electricity comes from a Goal Zero solar kit hanging on the side of the van
Looking at the side wall behind the drivers seat you can see the incredible beauty and craftsmanship in the van. The counter-top is held up by a commercial shelf unit.
The sink is simple but very practical. Below it he stores some of his carpentry tools so he can work on the road.
Because he has a high-top, he wanted to regain more vertical storage. space. So he built a storage shelf along the top, outside perimeter of the van. It doesn’t interfere with his movement in the van, but gains a lot of storage. In the previous photos you can see it’s also above the sink
He uses a futon mattress to sleep on which folds nicely to become a coach for lounging during the day and then a bed at night. At night he sleeps great and during the day he can move back and forth easily. An unexpected benefit of the slats in the bed is that it gives good ventilation to the mattress. Many times the moisture from perspiration can pool on the bottom sheet of plywood and in the morning it can be surprisingly damp. With the slats it vents very well and no moisture builds up.
In the picture below looking forward at the front you can see that he put in a swivel seat. Either reversing your seat so it faces backwards or getting a swivel seat is one of the very best things you can do in a van. They make excellent recliners that give you a very comfortable place to lounge. It also opens up the space and makes the van feel much larger and more open. If you reverse your seat, be very careful it doesn’t block your view of the side mirror or out the side window. That would be both illegal and very dangerous. His cooler is between the seats. You can also see that he’s continued the overhead storage all the way around the front of the van. Not only is his van truly beautiful, it’s very functional as well.
One of the things I loved the most about Andrew’s van is how he used the space on the door which is usually wasted. In the pictures below you can see he attached a cabinet onto one of the doors and he put his dogs water and food dishes on the other. Those of you with dogs know its a problem to find a place to keep their food and water dishes and this is a brilliant solution! The dog can reach them from either inside or outside and if they spill they do no harm because they fall onto the ground or onto the entry step. I loved this! The cabinet on the other door lets him to cook on it either inside or outside and use it for storage as well.
His dog’s food and water dish in on one door and the cabinet on the other. Both easily accessible inside or out. I guess I thought you would like a picture of my knee. No extra charge for that!
You can barely see the porta-potty on the bottom of the picture and he hangs items above it to use the space.
I hope you enjoyed this tour of Andrew’s Craftsman Van as much as I did and got some great ideas for your next build!
Andrew clearly knows how to use his particular skills and resources well. His van is indeed beautiful as well as highly functional. I noticed that outside of his specialties he keeps his systems simple, and I respect that as well.
I agree Calvin, mostly it’s very simple, just extremely well done. It epitomizes quality over quantity!
That is a great conversion. A lot of good ideas in that design.
Simply, WONDERFUL van !
Lucy.
PS: How creative to place the solar panels on the side of the van, easy, accesible to clean & to reposition then, GREAT IDEA !!!
Lucy, that’s a portable Goal Zero kit so it’s easy to set up and take down. One idea I’ve been thinking about is doing the same thing with the flexible solar panels hanging down the side. They have grommets so it would be super easy to attach them and take them off.
Very true Old Fat Man!
Nice setup! You used your space well. The bunk is very well done! Great craftsmanship! Thanks!
richard, Andrew really did a great job.
I love the idea that I could sleep on that bed without opening it but have the option of opening it if Dave went with me on a short jaunt.
It would be perfect for you Linda!
unless i am planning on staying put for a while most times i just sleep in futon mode. if my dog had any desire to sleep with me i might open it up more often but he would rather sleep in the front seats or under the bed. makes moving around easier.
You become wise by observing others Bob, and I become wise by observing you.
That’s very kind of you Man on the Run! But I hate to admit it but i am not all that wise, but I learned that lesson myself, so I observe the wise ones, like Andrew.
And now I’ve got you all fooled!
That is a work of art
Indeed it is tommy!
That bed idea is smart. I’ve seen it before (the design). Wisely done in this regard.
fablefox, It is a great idea. You’r right though, it is not the first time I’ve seen it either, but it is very well done.
Very nice setup. Has a good feeling to it.
Just wondering where he keeps his batteries for his solar?
Richard
Richard, I agree, it really is a warm and welcoming feeling.
It’s Goal Zero kit and they are portable so he can move it around, plus, I’m pretty sure they are quite small.
I loved so many of the unique ways he made a place for everything to be functional and so roomy, as needed. I love the idea of the kitchen on the door, and doggie dishes!
Me too Joy. Those were my favorites!
Bob, I have been wondering about all the weight placed on the doors ( the shelves, doggie dishes etc ) wouldn’t it pull the door down in such way as to be stressful to the door hinges ??
My regards, Lucy.
Lucy, I don’t think it is enough to be an issue. It could if you got carried away bu I don’t think he did.
Bob, where has he placed the batteries-bank ??
Lucy.
Lucy, because it’s a Goal Zero portable kit, he can move it anywhere he wants, it doesn’t take up much room.
So, do U mean to say that there are NOT batteries involved ??? If there are no batteries, where is the power stored ?
My regards, Lucy.
Lucy, no, it has a battery pack but it is small, portable and easy to move around and store. I don’t know which one he has, but it is probably something like this:
http://www.amazon.com/Goal-Zero-Solar-Generator-Nomad/dp/B00GV48YYI/
The battery looks like a car battery. i have not found its finally resting place in the van. as bob says it is very portable and when you get the chance you can take it inside a house to charge it up. I run LED lights and power my electronics with it. with no sun it last a couple days. with good sun the solar seems to keep up with the demand but never reaches 100%charge. i only have 60 watt solar. i am looking into getting a 100 watt panel and linking a couple smaller batteries to this to increase what i can actually power. it will charge while driving but my goal is not to turn the motor over unless i have to.
That’s the bed design I’ve been looking for, only better than what I’ve done!
Nice job on everything.
It really is a great job Rob!
Wow, that is a very nice conversion! Thank you for sharing it with us.
You’re very welcome Jim.
I love seeing these examples of how it’s done. What great craftsmanship! Though I aspire to van living, I don’t think it’ll happen anytime soon. Seeing examples like this though, gives me ideas for living in a smaller, less expensive space though.
Thank you Bob!
Sharon, every great thing done by humans began with dreams and inspiration, now that you are finding yours, hopefully your circumstances will line up to let them come true!
I bought this van 7 years ago. this was the second make over i did on it. I also wanted to live out of a van. I never did until this past thanksgiving. In the first 5 years it was a weekend warrior and summer vacation. also great for summer BBQ’s have a couple drinks then spend the night. but now my life is based 100% out of my van. sometimes in order to get to your dreams you have to make a step towards the goal. even baby steps are moving forward.
nice conversion! I love that you feature such a diversity of rolling homes, it demonstrates the breadth of human inventiveness and ingenuity. There are ideas there to inspire anyone, no matter how much money they have to work with.
Ming, there just is not only one way to do this thing! I’ve seen thousands of different setups and each worked well for it’s creator.
I love seeing how a craftsman customizes his work. Thanks.
Me too Cae! I could no more make my van look like his than I can fly to the moon, but I sure enjoy looking at his.
What an awesome conversion! I especially love the construction of the bed. Great workmanship.
Yes it is PJT!
Thanks Bob,
This was one of the best posts with the MOST ideas for a van to really make it homey as well as giving it a more spacious look. Love what he did with door tables. I also put a futon in my van and can use it as a bed or couch. I will bookmark this one and Try some of his ideas.
Can Andrew be hired to help others with van make overs?
I agree Lynnzie, it is a very good job! I’m not sure about the make-overs, but I doubt it.
I don’t know about building vans. i would love to do this as a job. problem is if i would charge $20 an hour it would add up fast costing as much as an already built van. part of the van community i have fallen in love with is everyone has there own style and everyone will help out another VanDwellwer. I think you build a connection and almost pride in living out of a van if you did the work to get you there. i used Bobs site for a lot of idea when building mine. I hope my van can help the next person as other vans have helped me.
Thought the van came out great,It’s really nice that everyone can do their Van’s to suit their needs. Im thrilled I found this site, about two years ago, I’ve been prepping to move into my van within the next few weeks, I’ll keep you posted when it happens and send Bob details and pictures of what has been put into my the project. So looking forward to sharing this with al of you. 🙂
Thanks Arkena, I always look forward to readers pics of their conversions and builds!
Where do van dwellers shower?
Nick, nearly all vandwellers without built in facilities use some use some combination of solar shower, sponge baths and wet wipes to stay clean and a urinal of some kind like a bottle or pot (women can use a funnel to direct it into a bottle) and for pooping either a porta potti or some kind of bucket like a 5 gallon or 1 gallon lined with bags. Some use it one time, others use it multiple times with kitty litter, peat moss, newspapers or other medium.
It looks like he covered over the windows completely on the drivers side? I have a conversion van and I am considering doing that in my build. Any idea what he covered them with before he attached the wood?
Bob, did you ever try the flexible solar panels held on with grommets? Is there more info for that?
